It is currently Tue Jun 24, 2025 4:05 pm
Post new topic Reply to topic  [ 542 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 22  Next
PostPosted: Mon Aug 06, 2012 11:40 am
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I've never built a concert uke, but out of all of the ones I have played, the ukes without fan bracing sounded the best.
PostPosted: Mon Aug 06, 2012 2:43 pm
First name: Tony
Last Name: C
City: Brooklyn
Interesting because I was thinking of a teeny, tiny Y shaped brace going from behind the sound hole with one tone bar. No idea what that will do but what the heck!
http://www.CostaGuitars.com
PMoMC
PostPosted: Tue Aug 07, 2012 11:23 pm
First name: Tony
Last Name: C
City: Brooklyn
Not that anyone cares, but I routed my rosette channel and then popped the pearl pieces in. I ended up having enough left over pearl from some past projects that I didn't need to order one. Guess that drops my total down to $43.54, except that the pearl wasn't free, so I will use the value of the Hana Lima rosette anyway, and my total is back to $54.54
Pics:
Thanks for looking....not that anyone is looking but I tend to end my picture posts with that, so why change?
Tony
PMoMC
PostPosted: Wed Aug 08, 2012 12:25 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That rossete sounds nice, I wish I had bothered to look at it.
Bryan Bear PMoMC
PostPosted: Wed Aug 08, 2012 5:24 am
First name: Tony
Last Name: C
City: Brooklyn
At least you read some of my words.
PMoMC
PostPosted: Wed Aug 08, 2012 7:00 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Ooops!! I clicked on this thread by mistake. A thousand pardons my friend!
Alex
PostPosted: Wed Aug 08, 2012 7:32 am
First name: Big
Last Name: Jim
Nice looking inlay Tony [:Y:] ermmmmmmmmm ..... not that I care an all laughing6-hehe
PostPosted: Wed Aug 08, 2012 7:43 am
First name: Tony
Last Name: C
City: Brooklyn
Listen, I'm not suggesting that people go out of their way not to care, but it was brought to my attention that nobody cares. If anyone happens to accidentally care, that's great! The rest of you can go on not caring.
Thanks Wud and Alex!
PMoMC
PostPosted: Wed Aug 08, 2012 7:59 am
First name: Big
Last Name: Jim
Ummmmmmmm well ... OK ... I guess I care a little . [:Y:]
PostPosted: Wed Aug 08, 2012 4:26 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Not that I care, but that's abalone, not pearl duh
It does look nice!
PostPosted: Wed Aug 08, 2012 5:02 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
It does look nice!
The inside the soundbox rossette is pearl. Tony gets confused. . .
NTIC
Bryan Bear PMoMC
PostPosted: Wed Aug 08, 2012 7:12 pm
First name: Tony
Last Name: C
City: Brooklyn
It's faux pearl with a painted on abalone pattern. Not that you all care.
Ok. It's real abalone. I call any shell product pearl. Even the clam.
PMoMC
PostPosted: Wed Aug 08, 2012 10:17 pm
First name: Tony
Last Name: C
City: Brooklyn
I glued on some braces tonight and the bridge patch. I don't know if I will add any more braces or not. I think maybe a tone bar or two. Time will tell.
Braces were cut from scrap spruce brace material. I don't know if I should assign a value or not. The brace block was $5.00 and was supposed to be enough for one guitar. These are the left overs and a piece of a sound board cut off for the bridge patch. Any thoughts?
Pics:
PMoMC
PostPosted: Wed Aug 08, 2012 10:24 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I think you may have cut your work-board a little over sized.
NTIC
Bryan Bear PMoMC
PostPosted: Wed Aug 08, 2012 10:28 pm
First name: Tony
Last Name: C
City: Brooklyn
Possibly. I am not known for my accuracy. NTYC.
PMoMC
PostPosted: Fri Aug 10, 2012 11:17 pm
First name: Tony
Last Name: C
City: Brooklyn
NTAC, but I did some stuff. Cut some pieces off of the neck blank I had to make a stacked heel.
Then I glued it up:
Then I glued on the two tone bars I plan on using. I cut them so they would not touch the bridge patch. Why? I don't know. It seemed like a good idea at the time.
I quickly realized I made the heel stack too big and that means I will have to cut it down quite a bit. That is better than making it too small I guess. Next up, a scarf joint for the headstock. NTAC, but thats what I will be doing.
Tony
PMoMC
PostPosted: Sat Aug 11, 2012 12:25 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Is the heel too big? I just thought this was going to be a DEEP bodied uke.
NTIC
Bryan Bear PMoMC
PostPosted: Sat Aug 11, 2012 9:11 am
Dread Uke? May need an armrest - NTAC
PostPosted: Sat Aug 11, 2012 11:48 am
First name: Tony
Last Name: C
City: Brooklyn
Not big like that, it's big as though I were doing a Spanish heel. I'm not. So I will need to chop off some of the length.
PMoMC
PostPosted: Sat Aug 11, 2012 2:28 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Nice looking work, Tony. That koa should look awesome under lacquer (assuming you're using lacquer). Not that I care though...
PostPosted: Sat Aug 11, 2012 2:58 pm
First name: Tony
Last Name: C
City: Brooklyn
I am using a one piece back for this ukulele but the orphan back plate I had was about 3/8ths too narrow. I probably could have covered the shortfall with binding and purfling, but I don't want to take the chance that it would not, so I added wings.
I know that nobody cares, but I think I need to post in order to comply with the rules showing how I did this.
Thanks for not looking.
Tony
PMoMC
PostPosted: Sat Aug 11, 2012 2:59 pm
First name: Tony
Last Name: C
City: Brooklyn
I would answer you and say that I am using lacquer, but it wouldn't matter because you don't care. So I wont tell you that.
PMoMC
PostPosted: Sun Aug 12, 2012 9:46 am
First name: Tony
Last Name: C
City: Brooklyn
I received a PM the other day, by accident of course, and the person who sent it accidentally mentioned they had some Ukulele tuners that I could have for free. Then, they accidentally put them in an envelop and completely unintentionally went to the post office and mailed them. They arrived the other day and they are very nice. I wanted to thank the person who sent them but they don't care......to be mentioned. In any event, and not that the person who sent them cares, and not that anyone reading this cares, but here is a pic of my accidental, free of caring tuners:
I would like to say thanks but again, the person responsible does not care to be revealed because then they might get some flack for actually reading this thread.
PMoMC
PostPosted: Sun Aug 12, 2012 11:01 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Wait! You're Tony Costa? the Tony Costa? Of Costa Guitars? Wow!
You're not fooling anyone. We all know you fabricated this story so you didn't have to count the tuners against your bottom line. Nobody would send you anything for this project.
NTIC
Bryan Bear PMoMC
PostPosted: Sun Aug 12, 2012 11:31 am
First name: Tony
Last Name: C
City: Brooklyn
That's right. I'm him. He is me. As I said, the whole thing was an accident.
PMoMC
